Hello SparkFun Technical Support Team,
I’m facing a boot issue with my Raspberry Pi 5 8GB. Initially, everything worked fine, but now it won’t boot up properly. Here’s what happens:
Symptoms:
Troubleshooting Steps Taken:
Software:
Hardware:
BIOS Information:
Without MicroSD/USB:
Raspberry Pi 5 - 8GB
bootloader: 3d0e0ba5 2023/10/30 update-ts: 1699652677
boot: mode USB-MSD 4 order f41 retry 0/128 restart 2/-1
SD: card not detected 00035344534331323880f51fcc8a012c
part: 0 mbr [0x0c0000000 0xc0000000 0xe0000000 0xe0000000]
power supply: USB-C 900 mA CC1 PMIC: reset normal 0x0 usb_over_current=0
net: down ip: 0.0.0.0 sn: 0.0.0.0 gw: 0.0.0.0
tftp: 0.0.0.0 0 0 0:0:0:0
display: DISP0: EDID-none #0 DISP1: DVI HPD=1 EDID=ok #4
Failed to Open device: 'sdcard' (cmd 371a0010 status 1fff0001)
Boot mode: USB-MSD (04) order f
USB2[2] 002206e3 connected
USB2[2] 002206e1 connected
USB2 root HUB port 2 init
HID [01:00] 2.00 000000:02 register HID
USB MSD stopped. Timeout: 25 seconds
Boot mode: RESTART (0f) order 0
Boot mode: SD (01) order f4
Failed to open device: 'sdcard' (cmd 371a0010 status 1fff0001)
USB2[2] 002206e3 connected enabled
With MicroSD/USB and EEPROM image:
boot: mode USB-MSD 4 order f41 retry 0/128 restart 25/-1
SD: card detected 00035344534331323880f51fcc8a012c
display: DISP0: HPD-0 EDID-none #0 DISP1: DVI HPD=1 EDID=ok #4
Trying partition: 0
type: 32 lba: 2048 'mkfs.fat' · NO NAME
Trying partition: 0
Trying partition: 0
Trying partition: 0
The Pi worked well for 4-5 days before this issue. I’ve included the BIOS details above for both scenarios. Any insights or guidance would be greatly appreciated as I’ve exhausted all the usual troubleshooting steps.
Thank you for your time and assistance!
Update on Raspberry Pi 5 Boot Issue:
There’s a new development in the boot behavior of my Raspberry Pi 5. The device now enters a loop where:
The LED starts green for about 1 second.
It then turns red for 1 second.
Subsequently, it goes off and restarts this cycle repeatedly.
This looping occurs only when a bootable medium with compatible OS (either a USB or MicroSD) is present. Without a bootable medium, the LED remains solid green. I’m increasingly concerned this might be a hardware issue, given the persistence of the problem and its evolution over time. Any further assistance or suggestions would be greatly appreciated.
Thank you again for your continued support.
Original Post: https://forums.raspberrypi.com/viewtopic.php?t=359658
