I’m using:
WinARM Version 20060606
OpenOCD - Version SVN88
( Open On-Chip Debugger (2006-08-01 12:00 CEST) )
ATSAM7A3-EK eval board
The code compile successfully in both IAR and GCC. But I’m only able successfully load to flash the IAR build. I’m not entirely sure if it is a GCC issue or a flash loading issue. Both builds seem to return success. But the GCC version doesn not run. Can someone verify this from the log file?
IAR build log: (openocd_log_iar_basic_insight.txt)
Debug: jtag.c:1180 jtag_init():
Debug: parport.c:358 parport_init(): requesting privileges for parallel port 0x378…
Debug: parport.c:368 parport_init(): …privileges granted
Debug: parport.c:203 parport_reset(): trst: 0, srst: 0
Debug: jtag.c:240 jtag_call_event_callbacks(): jtag event: 1
Debug: jtag.c:1070 jtag_reset_callback():
Debug: openocd.c:98 main(): jtag init complete
Debug: arm7_9_common.c:651 arm7_9_assert_reset(): target->state: unknown
Debug: jtag.c:240 jtag_call_event_callbacks(): jtag event: 0
Warning: arm7_9_common.c:675 arm7_9_assert_reset(): srst resets test logic, too
Debug: parport.c:203 parport_reset(): trst: 1, srst: 1
Debug: arm7_9_common.c:714 arm7_9_deassert_reset(): target->state: reset
Debug: jtag.c:240 jtag_call_event_callbacks(): jtag event: 2
Debug: openocd.c:102 main(): target init complete
Debug: openocd.c:106 main(): flash init complete
Debug: gdb_server.c:1093 gdb_init(): gdb service for target arm7tdmi at port 3333
Debug: embeddedice.c:155 embeddedice_read_reg_w_check(): 1
Debug: jtag.c:240 jtag_call_event_callbacks(): jtag event: 3
Debug: arm7_9_common.c:777 arm7_9_halt(): target->state: running
Debug: embeddedice.c:251 embeddedice_write_reg(): 9: 0xffffffff
Debug: embeddedice.c:251 embeddedice_write_reg(): 11: 0xffffffff
Debug: embeddedice.c:251 embeddedice_write_reg(): 12: 0x00000100
Debug: embeddedice.c:251 embeddedice_write_reg(): 13: 0x000000f7
Debug: arm7_9_common.c:615 arm7_9_poll(): DBGACK set, dbg_state->value: 0x19
Debug: embeddedice.c:251 embeddedice_write_reg(): 0: 0x00000005
Debug: embeddedice.c:251 embeddedice_write_reg(): 12: 0x00000000
Debug: arm7_9_common.c:907 arm7_9_debug_entry(): target entered debug from Thumb state
Debug: arm7_9_common.c:911 arm7_9_debug_entry(): r0_thumb: 0x0000b823, pc_thumb: 0x00000254
Debug: arm7_9_common.c:934 arm7_9_debug_entry(): target entered debug state in Supervisor mode
Debug: arm7_9_common.c:945 arm7_9_debug_entry(): thumb state, applying fixups
Debug: arm7_9_common.c:975 arm7_9_debug_entry(): entered debug state at PC 0x24e
Debug: target.c:439 target_call_event_callbacks(): target event 0
Debug: arm7_9_common.c:777 arm7_9_halt(): target->state: halted
Warning: arm7_9_common.c:781 arm7_9_halt(): target was already halted
Debug: gdb_server.c:124 gdb_get_char(): received ‘+$Hc-1#09’
Info: server.c:67 add_connection(): accepted ‘gdb’ connection from 0
Debug: gdb_server.c:989 gdb_input(): recevied packet: ‘Hc-1’
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$#00’
Debug: gdb_server.c:124 gdb_get_char(): received ‘+$qC#b4’
Debug: gdb_server.c:989 gdb_input(): recevied packet: ‘qC’
Debug: gdb_server.c:124 gdb_get_char(): received ‘+$qOffsets#4b’
Debug: gdb_server.c:989 gdb_input(): recevied packet: ‘qOffsets’
Debug: gdb_server.c:124 gdb_get_char(): received ‘+$?#3f’
Debug: gdb_server.c:989 gdb_input(): recevied packet: ‘?’
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$S02#b5’
Debug: gdb_server.c:124 gdb_get_char(): received ‘+$Hg0#df’
Debug: gdb_server.c:989 gdb_input(): recevied packet: ‘Hg0’
Debug: gdb_server.c:124 gdb_get_char(): received ‘+$pf#d6’
Debug: gdb_server.c:989 gdb_input(): recevied packet: ‘pf’
Debug: gdb_server.c:567 gdb_get_register_packet():
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$4e020000#bb’
Debug: gdb_server.c:124 gdb_get_char(): received ‘+$m24c,4#96’
Debug: gdb_server.c:989 gdb_input(): recevied packet: ‘m24c,4’
Debug: gdb_server.c:669 gdb_read_memory_packet(): addr: 0x0000024c, len: 0x00000004
Debug: arm7_9_common.c:1630 arm7_9_read_memory(): address: 0x0000024c, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$8842fad3#34’
Debug: gdb_server.c:124 gdb_get_char(): received ‘+’
Debug: gdb_server.c:124 gdb_get_char(): received ‘$qRcmd,706f6c6c#58’
Debug: gdb_server.c:989 gdb_input(): recevied packet: ‘qRcmd,706f6c6c’
Debug: arm7_9_common.c:615 arm7_9_poll(): DBGACK set, dbg_state->value: 0x9
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$O7461726765742073746174653a2068616c7465640a#76’
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$O7461726765742068616c74656420696e205468756d622073746174652064756520746f20646562756720726571756573742c2063757272656e74206d6f64653a2053757065727669736f720a#8f’
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$O637073723a20307834303030303031332070633a20307830303030303234650a#8b’
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$OK#9a’
Debug: gdb_server.c:124 gdb_get_char(): received ‘$qRcmd,666c61736820696e666f2030#a0’
Debug: gdb_server.c:989 gdb_input(): recevied packet: ‘qRcmd,666c61736820696e666f2030’
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$O23313a206174393173616d3720617420307830303030303030302c2073697a6520307830303030303030302c20627573776964746820302c2063686970776964746820300a#58’
Debug: arm7_9_common.c:1630 arm7_9_read_memory(): address: 0xfffff240, size: 0x00000004, count: 0x00000001
Debug: at91sam7.c:310 at91sam7_read_part_info(): nvptyp: 0x002, arch: 0x0060, alt_id: 0x0000, alt_addr: 0x3fac08
Debug: arm7_9_common.c:1630 arm7_9_read_memory(): address: 0xfffffc24, size: 0x00000004, count: 0x00000001
Debug: arm7_9_common.c:1630 arm7_9_read_memory(): address: 0xfffffc30, size: 0x00000004, count: 0x00000001
Debug: arm7_9_common.c:1630 arm7_9_read_memory(): address: 0xfffffc2c, size: 0x00000004, count: 0x00000001
Debug: arm7_9_common.c:1630 arm7_9_read_memory(): address: 0xffffff68, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$O0a#e0’
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$O6174393173616d3720696e666f726d6174696f6e3a0a#da’
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$O636964723a20307832363061303934312c20617263683a203078303036302c206570726f633a2041524d3754444d492c2076657273696f6e3a30783030312c2020666c61736873697a653a20307830303034303030300a#83’
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$O6d617374657220636c6f636b28657374696d61746564293a2034383136376b487a200a#4d’
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$O7061676573697a653a203235362c206c6f636b626974733a203136203078666666382c20706167657320696e206c6f636b20726567696f6e3a203634200a#89’
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$O73656375726974796269743a20302c206e766d626974733a203078300a#48’
Debug: gdb_server.c:124 gdb_get_char(): received ‘$qRcmd,666c617368207772697465203020453a5c42617369632e62696e20307830#50’
Debug: gdb_server.c:989 gdb_input(): recevied packet: ‘qRcmd,666c617368207772697465203020453a5c42617369632e62696e20307830’
Debug: at91sam7.c:638 at91sam7_write(): first_page: 0, last_page: 4, count 1024
Debug: at91sam7.c:226 at91sam7_set_flash_mode(): fmcn: 73
Debug: arm7_9_common.c:1771 arm7_9_write_memory(): address: 0xffffff68, size: 0x00000004, count: 0x00000001
Debug: arm7_9_common.c:1771 arm7_9_write_memory(): address: 0x00100000, size: 0x00000004, count: 0x00000040
Debug: arm7_9_common.c:1771 arm7_9_write_memory(): address: 0xffffff64, size: 0x00000004, count: 0x00000001
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000001, pagenumber:
Debug: at91sam7.c:243 at91sam7_wait_status_busy(): status: 0xfff80001
Debug: at91sam7.c:661 at91sam7_write(): Flash command: 0xffffffff, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000101, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000201, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000301, pagenumber:
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$O77726f74652066696c6520453a5c42617369632e62696e20746f20666c6173682062616e6b2030206174206f6666736574203078303030303030303020696e2030732031353632353375730a#82’
Debug: gdb_server.c:124 gdb_get_char(): received ‘$qRcmd,73687574646f776e#e1’
Debug: gdb_server.c:989 gdb_input(): recevied packet: ‘qRcmd,73687574646f776e’
GCC build log: (openocd_log_gcc_basic.txt)
Debug: arm7_9_common.c:911 arm7_9_debug_entry(): r0_thumb: 0x0001f291, pc_thumb: 0x0000024c
Debug: arm7_9_common.c:975 arm7_9_debug_entry(): entered debug state at PC 0x246
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$46020000#8c’
Debug: gdb_server.c:124 gdb_get_char(): received ‘+$m244,4#67’
Debug: gdb_server.c:989 gdb_input(): recevied packet: ‘m244,4’
Debug: gdb_server.c:669 gdb_read_memory_packet(): addr: 0x00000244, len: 0x00000004
Debug: arm7_9_common.c:1630 arm7_9_read_memory(): address: 0x00000244, size: 0x00000004, count: 0x00000001
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$00e0401c#ed’
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$O637073723a20307834303030303031332070633a20307830303030303234360a#89’
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$O6d617374657220636c6f636b28657374696d61746564293a2034383137386b487a200a#4f’
Debug: gdb_server.c:124 gdb_get_char(): received ‘$qRcmd,666c617368207772697465203020453a5c6d61696e2e68657820307830#22’
Debug: gdb_server.c:989 gdb_input(): recevied packet: ‘qRcmd,666c617368207772697465203020453a5c6d61696e2e68657820307830’
Debug: at91sam7.c:638 at91sam7_write(): first_page: 0, last_page: 34, count 8488
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000401, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000501, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000601, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000701, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000801, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000901, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000a01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000b01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000c01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000d01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000e01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a000f01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001001, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001101, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001201, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001301, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001401, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001501, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001601, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001701, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001801, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001901, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001a01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001b01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001c01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001d01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001e01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a001f01, pagenumber:
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a002001, pagenumber:
Debug: arm7_9_common.c:1771 arm7_9_write_memory(): address: 0x00100000, size: 0x00000004, count: 0x0000000a
Debug: at91sam7.c:268 at91sam7_flash_command(): Flash command: 0x5a002101, pagenumber:
Debug: gdb_server.c:160 gdb_put_packet(): sending packet ‘$O77726f74652066696c6520453a5c6d61696e2e68657820746f20666c6173682062616e6b2030206174206f6666736574203078303030303030303020696e2030732038393036343275730a#5b’
