Tsunami super wav trigger config won’t update
Using super wav trigger qwicc. I am using the configuration app to update trigger actions. The board does not accept the new trigger actions from the micro so card. Some triggers are retaining their previous settings. I have followed the instructions in the user guide and tried several times. The board works, just with old trigger settings. Does the firmware perhaps need to be updated? Thx
The WAV trigger loads it’s sertings every power up, it doesn’t have the ability to remember your old settings. Double check your config file. If needed, format the card and put the new config and your WAV files back on.
Thx for response, I will do as you suggest
