Using the RTK Surveyor Kit or RTK Express as A Base to use with DJI M300 Drone
Hi there,
First of all, i really love all the work you all on are doing it looks great!!. Im here wanting to know if it possible to use the RTK Surveyor/Express to be used as a Base to send Corrections via NTRIP to DJIs M300RTK
The RTK units do allow for NTRIP broadcast/client, so as long as the DJI isn’t using some proprietary version of NTRIP and/or encoding over their bluetooth/wifi/serial it should work fine
Thank You Russel for your response, I know that the DJI m300 rtk is compatible with other Base Stations aside from the D-RTK. Does the RTK Surveyor have an NTRIP client that can used?
Hi there, sorry Im not sure i may have missed it but what is the baseline for RTK Surveyor and RTK Express?
