I want to use some Lumenati modules outside where they will be exposed to water.
Has anyone sealed them with a spray of some kind successfully or maybe coated them with clear epoxy?
I would rather not have to put them in an enclosure for space reasons.
Thanks Kurt
Hi Kurt.
We haven’t tried this, but coating the board with epoxy should work. You will probably want to use an epoxy that has some protection against UV light though, you wouldn’t want the epoxy to yellow or break down in the sun.
good point about the UV stability
