I have hooked up the Gator:bit to the Gator:environment and am trying to get the results displayed on a serial monitor on my Mac. I am not having any luck. It seems to be connecting, but no data is showing. Any help would be appreciated!
Are you using a v2 microbit or the older v1? I think there are some compatibility issues using v1 code on a v2 microbit.
Also, have you put the code on your microbit or did you just connect the parts together? Without code on the microbit, nothing is going to happen.
