I am getting the same issue when trying to use the serial terminal to access the torch when using tera term on windows. “Pressing any key” pops up with the same error and no way to access the menu. Did anyone find a work around? I can’t get SW maps to connect as a ntrip client with my torch so I’m trying to manually configure the torch to get corrections so I need to access the serial terminal instead of just using bluetooth.
